You guys are so cute...trying to catch me missing a deck violation...
Pcinspector1 said:
Glenn,Is this a deck being build over a utility easement?
pc1
Nope. Planning division looks at that. They approved it.
north star said:
In lieu of there not being any specific language directly addressing FSD's,
you might consider using Section R104.11 [ from the `12 IRC ]:
"Alternative materials, design and methods of construction and equipment:
The provisions of this code are not intended to prevent the installation of any
material or to prohibit any design or method of construction not specifically
prescribed by this code, provided that any such alternative has been approved.
An alternative material, design or method of construction shall be approved
where the building official finds that the proposed design is satisfactory and
complies with the intent of the provisions of this code, and that the material,
method or work offered is, for the purpose intended, at least the equivalent
of that prescribed in this code...........Compliance with the specific performance
-based provisions of the International Codes in lieu of specific requirements
of this code shall also be permitted as an alternate."
Also, the BO can craft policy or policies to address the flammable &
combustible nature; as well as, the FSD's of the decks and their locations
[ RE: Section R104.1, `12 IRC ].
The trick is to have an accurate review of an accurate Scope of Work
from the contractor, ...B E F O R E anything is constructed.
I love 104.11, but I can't really say this is an issue of an alternative being proposed. We considered a policy about this, but the decision was to wait until our official amendments and adoption of the 2015. I'm pretty confident we will address it with an amendment...but in what manner? This is why I hope this discussion turns into a technical one about fire behavior on decks.
jar546 said:
I wonder what the POCO has to say about the electrical meter base and it's new location now that there is a deck in front of it, lowering the height?Now that those windows are part of a walkway, are they being changed to safety glazing?
I should have known this would happen if I post a picture in front of you hawks! ha, ha!
Our utility has no specifications for how "low" a meter base can be. All we lean on with that is our "anticipated snow accumulation" of 12 inches, suggesting that panels should be at least above the anticipated snow level. The windows do not meet all four requirements for safety glazing required at walkways, so it's not required. I've been looking at safety glazing by decks since I wrote an article on the subject back in 2007.
http://www.deckmagazine.com/Images/STRUCTURE_tcm122-1378437.pdf
mtlogcabin said:
It might be a stretch but here goes2009 IRC
EXTERIOR WALL. An above-grade wall that defines the exterior boundaries of a building.......
BUILDING. Building shall mean any one- and two-family dwelling or portion thereof, including townhouses , that is used, or designed or intended to be used for human habitation, for living, sleeping, cooking or eating purposes, or any combination thereof, and shall include accessory structures thereto.
Is a deck an accessory structure to a SFR?
Do the support post define the exterior wall line?
The space between the supporting post are the just "openings" within the wall?
Table R302.1 1-hour if less than 5 feet
Unlimited openings in the "wall" 5 ft.
Do the support post on a carport define the "exterior wall" line? Why would a deck be any different?
EXTERIOR WALL. An above-grade wall that defines the exterior boundaries of a building.............Includes between-floor spandrels, peripheral edges of floors,
In reality is a deck just an exterior floor?
I've looked at this interpretation before, (calling the area between the posts an "opening" in an exterior wall), but again...it just feels like a stretch, and like that's not really what those provisions were intended for. This is why I believe the IRC should really address decks specifically. The reason this particular deck would be different from a carport is because of how low to the ground it is, but that's a really good comparison to consider.
Pcinspector1 said:
Glenn,The reason I asked if the deck in the picture is over a utility easement, we have a 7.5 utility easement on both sides of a property line in most new subdivisions. The POCO could request a fence be removed if in an easement. If this is just a normal SE or other utility to a residential structure it would be allowed to go beneath the deck.
Zoning here would not allow that deck to be build if it is beyond the 8' PL setback here. So sometimes the building code should be enforced after the zoning code IMHO.
pc1
Yeah...normally our planning division has a 5 foot setback, so I've never faced this issue. This particular neighborhood finished it's build-out about a year ago, so only now are we starting to get deck submittals. This is the first time I've not been able to "blame planning", and we have to address it. Zero side setback.
Good stuff, guys, I do love the responses! However, my division made the call to let this happen, so it's happened. I'd like to learn more about this issue and how to craft good code to address it in the future (our 2015 amendments, or a 2018 proposal to the hearings). Is there a way to distinguish between when the hazard is fire from above or fire from below. What if the deck was literally sitting on the ground? What if it was second story? non-combustible material? There is obviously a significant difference between the nature of fire spread between various decks.
