Fire Sprinkler Systeme & Antifreeze
Marshal Chris
Silver Member
Long Island, NY
Hello all!
I am not sure if you have seen the LFP Antifreeze solution from Tyco. You can find the technical info here:
https://www.tyco-fire.com/TD_TFP/TFP/TFP1680_10_2018_A.pdf
Has anyone approved this or seen a submittal for it?
It doesn't say UL "Listed" but UL "Certified" and I'm not sure whether it makes a difference. I have not seen anything from NFPA indicating approval, not that I would expect that either.
Thoughts?
Do read the limitations
The tech sheet is poorly written
