Fire Sprinklers needed R2 single story apartments?
RPM001
Ft. Lauderdale FL
Have a quick question about Fire Sprinkler Requirements.
Building 14 apartments (single story, R2 occupancy type) spread out in 3 buildings. Each unit is identical 2 bed/ 2 bath 1200 sq ft.
1 building has 3 units, another 5 units, and the last one has 6 units. Typical south Florida construction (project located in Ft. Lauderdale) Concrete block shell, but the dividing walls between units to be fire rated drywall, etc.
Does current code require fire sprinklers and/or fire alarm in this scenario?
More than likely sprinklers, and at least monitoring.
There is a Floridian that can answer that.
You may be able to construct them under the IRC townhouses which would give you a better chance of getting out of them, but that is up to Florida if that is where the construction is...
