DTBarch
I feel like this answer is intuitive, but it's one of those that is not necessarily addressed specifically in the code (that I know of). I know that my crack team of fellow Sawhorse members can enlighten me as usual...
Given: Existing "L" shaped office building, Type IIIB construction, non-sprinkled. One side of the "L" is a 2 story CMU structure, with the 2nd floor measuring approx. 1,800sf (no elevator). The other leg of the "L" is a 1 story concrete tilt panel structure. Client prospect wants to add a 2nd floor to the tilt panel structure building.
Question A: Per Section 1104.4 of the 2012 IBC, for a B occupancy, they can have a max of 3,000sf on the 2nd floor before they need an elevator. If the existing 2nd floor and the new 2nd floor area are separated by a fire wall, used by the same single tenant, with existing and proposed 2nd floor areas having access to each other by way of a fire rated door, does that affect the calculation of the 2nd floor area that is regulated by Section 1104.4. In other words, are they limited to 1,200sf for their new 2nd floor area (1,800+1,200=3,000sf), OR does the existence of the fire wall provide for separation of the max floor area for the elevator requirement, thereby allowing them to build out up to the 3,000sf limit of new 2nd floor area without an elevator?
Question B: On a related, but separate topic, as a B occupancy (general office) with the proposed total building area (after 2nd floor expansion) falling under the tabular max area and height, I don't believe there is anything else that would trigger a requirement to add fire sprinklers to this existing non-sprinkled building. Am I missing anything obvious on that?
