aztec
- Joined
- Sep 2, 2011
- Messages
- 16
I have a H5/Type II B fully sprinkler building, and need to change my 3hr fire barrier to a 3hr fire wall. Turns out a lot of the material has already been ordered and mechanical/structural will have to make many adjustments if I cannot remove the 30 in parapet requirement.
Section 706.6 Vertical Continuity (IBC 2009), exception 3 seems to be the saving grace: "Walls shall be permitted to terminate at the underside of noncombustible roof sheathing, deck or slabs where both buildings are provided with not less than a class B roof covering. Operings in the roof shall not be located within 4 feet."
I have a TPO roof covering, which as of right now I do not know what was specified (just got on the project). I do know the metal deck is ordered and is galvanized, and is not fire rated.
IF the TPO is is class B AND the metal deck is noncombustible, then I should be ok to terminate the 3hr wall at the bottom of the deck? Does that sound correct?
IF the galvanized metal deck is combustible, then do I have any options? I was told I could spray something on the underside of the deck, but of course structure mentioned galvanized deck do not take materials very well.
Any thoughts or suggestions would be great. Thanks.
