Given:Existing building: Type II-A construction (does not have automatic fire suppression)Code: 2012 IBCNew Building: Type II-B – 2 story with automatic fire suppressionA firewall will be required due to budget limits cannot add fire suppression to the existing building. Therefore; two separate buildings.Issue;The delivery dock is to be expanded. However, they also want a cover over the expanded dock. It will be an open dock. The building’s roof lines do not extend beyond the firewall. We are extending the firewall out beyond the roof lines of the buildings. The question is; can we use a canopy cover over the extended exposed dock that would not be an actual part of the building’s roof? Of course the canopy (flesh color shaded area) would be non-combustible construction. I have attached a PDF of the area. The design is still in schematics.
Covered Dock with Firewall.pdf
