    Dismiss Notice
    Dismiss Notice
Fixtures vs Facilities in Table 403.1
Discussion in 'Plumbing Codes' started by georgia plans exam, Nov 16, 2017.
  1. georgia plans exam
    georgia plans exam Silver Member
    Oct 19, 2009
    354
    10
    Does anyone know why footnote "d" to Table 403.1 (2012 IPC) refers to the minimum number of "facilities" required, rather than the number of "fixtures"?
    Thanks, GPE.
  2. Rick18071
    Rick18071 Sawhorse
    Nov 28, 2009
    1,543
    130
    Good one. I wonder if it is a misprint. says the same thing in the 2009.
  3. mtlogcabin
    mtlogcabin Sawhorse
    Oct 17, 2009
    6,925
    651
    403.2 through 403.4 deal with facilities and minimum requirements
  4. rgrace
    rgrace Sawhorse
    Feb 18, 2010
    143
    24
    That is a good question. Thought provoking :)
    Facilities contain plumbing fixtures. The location of a facility is limited by distance. The number of facilities is dictated by the number of occupants (minimum two facilities, discounting exceptions, on for each sex) and distance. Depending on the location of the seasonal outdoor seating and entertainment areas under A-1, A-2 and A-3, additional facilities may be required based on distance. The bigger question now is, if the intent was to verify distances to facilities, is the additional occupant load required to be included in the minimum plumbing fixture count? This footnote doesn't really say that it is. If it did, it would end with "shall be included when determining the minimum number of plumbing fixtures and facilities required."
  5. rgrace
    rgrace Sawhorse
    Feb 18, 2010
    143
    24
    FYI, 2015 and 2018 has the same language as well.
  6. Builder Bob
    Builder Bob Sawhorse
    Oct 17, 2009
    1,964
    255
    The first time I see that language is in the 2006 IPC , it has a black bar indicating a code change, You may have to go to the archives to see what the intent of this"language" is....
  7. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    9,804
    589
    Base on the definition, in dictionary, not code book.
    A facility can contain many fixtures. Case in point a education facility can contain many classrooms or resroom facilities
    But a fixture can not.
    JBI likes this.
  8. HForester
    HForester Member
    Sep 21, 2015
    125
    39
    I dug back into the old proposal books to find that "facilities" is what was in the approved proposal (by Ballanco)
  9. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,660
    234
    Interesting to note that distance to facilities is only addressed for A occupancies, what of E occupancies?
  10. mark handler
    Oct 25, 2009
    9,804
    589
    Based on my contact with DSA, In CA, ASS-U-ME the students are "customers".... upload_2017-12-15_11-14-16.png
  11. ADAguy
    ADAguy Sawhorse
    Sep 11, 2013
    2,660
    234
    Well over 100 yards, how fast can a manual or electric wc cover that distance? < 20 sec's?
  12. Builder Bob
    Oct 17, 2009
    1,964
    255
    Same as I - Codes IPC 403.3.3 or IBC 2902.3.2.
  13. georgia plans exam
    Oct 19, 2009
    354
    10
    Thank you all for your replies. I had an applicant who wanted to use the wording in the footnote as an argument that the code saw no difference between facility and fixture. He did not want to provide separate facilities for each sex. long story but, he lost the argument. Thanks again...GPE.
  14. Francis Vineyard
    Francis Vineyard Sawhorse
    Jan 1, 2010
    3,113
    415
    Noted the footnote d is applicable to A-1, A-2 & A-3; not A-5 that would provide permanent (seasonal) facilities. Therefore could the other assembly groups provide portable facilities during the outdoor events (Ref. IBC E105.1)?
  15. georgia plans exam
    Oct 19, 2009
    354
    10
    Oops. Accidental double post.
  16. georgia plans exam
    Oct 19, 2009
    354
    10
    The footnote was not even applicable to the project. The applicant was trying to justify a code violation by quoting what, I beli
  17. georgia plans exam
    Oct 19, 2009
    354
    10
    believe is a poorly written footnote. GPE.
Share This Page
