Coug Dad
Platinum Member
A question about the quantity of flammable liquid. I have a pump that pulls a Class I-A liquid from a drum and pipe to a piece of equipment where the liquid is coated on a product. It is clearly an open system because the coating process is open to the air and a vented hood system is needed to contain the vapors. In calculating the volume of liquid to see if I am under the exempt quantity or if I am a Group H, which do I count?
a. liquid in the machine
b. liquid in the piping system
c. liquid in the drum
d. all of the above
Intuitively, it seems to me that the answer is "d" because a break or malfunction could cause the liquid to leak and the pump to continually draw from the drum until the remaining contents of the drum is depleted.
Any code references would be appreciated.
d. all of the above
