Robert Ellenberg
I have always specified and used Z flashing at horizontal joints and have assumed it was a code requirement as well as a good practice. However, I haven't created a rain screed space with cement siding before so I considered the Z very important for keeping water out from behind the siding. I am now going to cover the exterior framing with 1" thick foam (OC pink or Dow blue--not bead board) and tape the joints to meet the WRB requirements. Then I am going to add 1/4" thick vertical battens over the studs and 1/4" spacers every 6" on the horizontal joint lines to create a rain screed space for any penetrating water to run down and out. Once my siding sheets are in place I will cover the joints with cement board batten strips.
I was planning to use Z flashings at the horizontal joints but with a proper rain screed space they are not needed. After looking at the code, I'm not sure if they are required or not. R703.8 doesn't require it. R703.10 specifies caulking or batten strips on the joints.
I am also curious to know if anyone can explain the note U next to Fiber Cement siding listed in the table R703.4 next to the WRB requirement. U refers to the WRB exceptions in R703.2 and if you go there, #2 refers you back to 703.4. It appears to be a circular reference without meaning anything.
