MikeC
Silver Member
Does a detached garage require floor drains under the 2009 I-codes?
Our local sanitary authority had always required garage drains to be connected to the sanitary sewer system, stating it is a Pennsylvania DEP requirement (not sure, I have never seen it). I just approved plans for a 3 stall garage (U occupancy) which calls for floor drains. I made a note on the plans requiring these drains to hook into the sanitary sewer. The contractor is wishing to eliminate these floor drains, claiming that it would be too difficult to access the sanitary sewer. I have reviewed both the IBC & the IPC, but found no requirement for floor drains. Obviously, this would change the slop of the floor. Additionally, there is no water supply to this building.
Does anyone know of this PA DEP requirement or where I can find it?
