Yikes
Older versions of the CBC use to refer to opening force as applying to the doors, not the hardware. More recent versions of both ADA and CBC 11B-404.2.7 for "door hardware" refer to 309.4 which limits maximum force on operable parts: "The force required to activate operable parts shall be 5 lbs. maximum."
2013 CBC 1008.1.9.1 is amended to additionally refer us over to Calif. Referenced Standards Code 12-10-2 for "operating devices on doors required to be accessible by... Chapter 11B...". I don't see 12-10-2 as addressing panic hardware, however, California Referenced Standards Code 12-10-3 does:
Sec. 12-10-302.
(a) Releasing pressure. Exit panic hardware mechanisms shall be designed to release the door latch or latches when pressure not to exceed 15 pounds is applied at any point along the cross-bar perpendicular to the door in the direction of exit travel.
Which governs? The 5 lbs. or the 15 lbs.? Industry standard for most panic hardware is 15 lbs. for the mechanism. Does anybody know of one that works at 5 lbs. maximum?
Sec. 12-10-302.
