Electritek
Needing some info on garage floor drain. Have read codes that garage floor must slope out or to a drain. Have new residential construction with attached garage. The builder installed what he identifies as floor drain. I drained the livewell from my boat in garage floor. Floor is completely flat without any slope to drain or towards door. I swept the water down the floor drain. Two days later garage smelled like rotten fish. I thought P trap was dry so I ran water down drain. Next day whole house smelled like rotten fish. Garage floor drain has a 12" X 12" steel grate. I removed steel grate and looked and there is a shower drain in concrete. After removing the shower drain cover I looked in hole with flashlight. It's not hooked to nothing and merely drains into the gravel below my garage floor slab. Something smells fishy with this drain!! Is this code and EPA compliant.
