Francis Vineyard
Can someone point to specific language in the code to require under stair protection in the drawing presented below?
My guess the stairs would be considered habitable in a broad sense as it would not be allowed to not provide protection for similar areas between habitable spaces above the garage.
The underside of the stair is exposed to the garage. The stair is enclosed above to separate it from the garage.
The stair is not a habitable space as defined (similar to halls IMO).
HABITABLE SPACE. A space in a building for living, sleeping, eating or cooking. Bathrooms, toilet rooms, closets, halls, storage or utility spaces and similar areas are not considered habitable spaces.
TABLE R302.6 DWELLING/GARAGE SEPARATION
[TD=align: center] SEPARATION [/TD]
[TD=align: center] MATERIAL [/TD]
[TD=align: left]From the residence and attics[/TD]
[TD=align: left]Not less than 1/2-inch gypsum board or equivalent applied to the garage side[/TD]
[TD=width: 327, align: left]From all habitable rooms above the garage[/TD]
[TD=width: 309, align: left]Not less than 5/8-inch Type X gypsum board or equivalent[/TD]
[TD=width: 327, align: left]Structure(s) supporting floor/ceiling assemblies used for separation required by this section[/TD]
[TD=width: 309, align: left]Not less than 1/2-inch gypsum board or equivalent[/TD]
[TD=width: 327, align: left][/TD]
[TD=width: 309, align: left][/TD]
R302.7 Under-stair protection.
Enclosed accessible space under stairs shall have walls, under-stair surface and any soffits protected on the enclosed side with 1/2-inch (12.7 mm) gypsum board.
