GFCI Lightning Behavior
Francis Vineyard
Charlottesville, VA
It seems under certain conditions garage appliances will trip the GFCI during a lightning storm. My assumption is when the voltage surge force by lightning changes the potential between the hot and both the neutral and grounding circuit it will trip the GFCI; if this is correct would surge protection before the GFCI work?
Is the appliance a part at fault?
Thoughts!
Francis
Surge protection is not designed to protect equipment from nearby lightning strikes.
Tom Harris said:
All surge protectors are not created equal. In fact, there is a tremendous range in both performance and price of protection systems.
  • At one end, you have your basic $5 surge protector power strip, which will offer very little protection.
  • On the other end you have systems costing hundreds or even thousands of dollars, which will protect against pretty much everything short of lightning striking nearby.
