chris kennedy
Sawhorse
Was asked to call an inspector this afternoon about a shed our guys wired. Shed was pre-wired by manufacture with one GFCI rec and a duplex one would assume was on the load side yet was not.
His question to me was do shed rec's need GFCI protection. Reading 210.8(A)(2);
(2) Garages, and also accessory buildings that have a floor
located at or below grade level not intended as habitable
rooms and limited to storage areas, work areas,
and areas of similar use
If shed is on a 4" slab and shed floor is supported on 4×4's would you consider that on grade level?
Thanks
Thanks
