Mr. Inspector
To use 2018 Table R602.7(3) Girder and Header Spans for Open Porches acording to footnote c you need to use the measurement of the porch depth measured horizontally from the building face to the centerline of the header. I am not sure that you can only use this table when the header is parallel with the building exterior wall. I can't figure out why the spans would need to be different if the I used width of the porch roof when the headers were perpendicular to the exterior wall. Also it doesn't say if it is to be a shed, peaked or flat roof.
Can you use this table if the porch headers are not parallel with the building or when not attached to a building and a porch with a shed, peaked or flat roof?
