Plan review did not note tempered glass on all the walls, are they required to be tempered?
Even in a curtain wall should the glass above and around a sliding door be tempered? Plans did not indicate tempered glass above or to the side of the slider, is this usually a given or do I need to make note on review?
Do you use a special inspector durning construction?
