Government building access question
VillageInspector
Sawhorse
Dutchess County, New York, United States
My municipality has a handicap ramp leading to a handicap entrance in a remote portion of the building which for security purposes is kept locked. Currently when a handicap person comes to that door they push a buzzer to let someone know they are there and someone then goers to that door to open it for them. Is this compliant? I don't believe so. Would a remote lock release suffice? I maintain that if other door is unlocked and readily accessible to healthy people the handicap should be as well however I can't seem to find ADA or building code language to make my argument. Any help would be greatly appreciated.
Thanks in advance for your help..
Not ada, but does it fall under reasonable accommodation ?
Does ada say you have to leave a building unsecure?
In existing construction, Can you divert people to an alternate access point Yes.
Can it be locked, Questionable.
I guess that's my question. In my mind if a healthy person can gain access unobstructed shouldn't a handicap person have the same ability rather than have to sit in the heat, cold, snow, rain etc until someone comes to open the door?
I would not be comfortable with it being locked. The intent of the law is to provide an equal amount of access. What you are describing is not an equivalent level of access.
So if an exterior lift was installed, for access, the person would have to """sit in the heat, cold, snow, rain etc"""
And seems like you are talking about an existing building, not new.
An example is a (historic) court house where the public can enter the main entrance unlocked during business hours but the wheelchair ramp is accessed on the side of the building where a guard is alert by a "buzzer" from the outside to allow entry at an area that does not have the space for the metal detector.
Provide a cover for the "alternate" entrance.
There is nothing in the code that says the "alternate" entrance shall not be restrictively controlled.
I would like to see, but not in code, the same requirements as a "Area of Refuge", Voice communication.
Can we do this at all government buildings? There are days....
Does the public have access to your building? Many Governmental offices are by appointment only.
Many Governmental buildings have restrictive controls.
You can restrict the access but, Who do you answer to?
Restricted access for all but not discriminatory access.
If one required entrance is accessible and building has two (2) required then both must be self accessible by those with disabilities too.
Yes this is a municipal building. Front door is open during office hours but handicap entrance is locked.
What ADAGuy is implying is The accessible entry should have the same level of access as all other entries. Can you be sued, yes. Try to mitigate it by providing more than just a bell.
Cover the waiting area, provide voice communication.
