jpowell
Bronze Member
Hi All,
Need a little help here. What is your opinion on needing 2-HR rated exterior walls on this grain silo. It seems silly, because it is a silo - it is made of metal and there is no good way to create a rated wall.
Here is the situation. Small local brewery is doing a small expansion. As part of this they want to install a small grain silo. S-1. It is a separate structure, but is close to the lot line and the new/existing structure. Areas are small enough that they can consider the whole site as one building and don't need fire separation between the structures.
Where I need opinions is the distance to the lot line. The silo is about 1' from the lot line. Per 602 this would require 2-HR exterior walls within 5'. (2012 IBC) Also possibly relevant is a 16' access easement from the property line, so no structures will be built closer than that.
Silo stats:
10' diameter
79 sf
26' tall
2042 cf
Thanks for any thoughts!
Silo stats:
10' diameter
79 sf
26' tall
2042 cf
