Mac Moonfire
Hi,
In regards to the graspability of handrails, the British Columbia Building code requires a continuously "graspable" handrail.
In my interpretation of the code, "graspable" is defined by:
9.8.7.5.(2) All handrails shall be constructed so as to be continually graspable along their entire length with no obstruction on or above them to break a handhold. (See Note A-9.8.7.5.(2).)
A-9.8.7.5.(2) Handrail Sections.
Handrails are intended to provide guidance and support to stair users. To fulfil this intent, handrails must be “graspable.”
The graspable portion of a handrail should allow a person to comfortably and firmly grab hold by allowing their fingers and thumb to curl under part or all of the handrail. Where the configuration or dimensions of the handrail do not allow a person’s fingers and thumb to reach the bottom of it, recesses that are sufficiently wide and deep to accommodate a person’s fingers and thumb must be provided on both sides of the handrail, at the bottom of the graspable portion, which must not have any sharp edges.
- a recess, on both sides, permitting fingers and thumb to curl under part if not all of the handrail.
- no sharp edges
