ccbuilding
Sawhorse
Probably a very simplistic question, but I’m still trying to learn the basics for electrical.
A homeowner ran a circuit from house panel to sub-panel in garage. She ran 2-#2’s and 1-#6. There is a UFER ground in place.
I wasn’t sure if this was a correct configuration, and told her she needed a neutral to complete the circuit properly. She wanted to know if she could use the #6 as her neutral, and use the UFER at the garage as her ground.
Would this work? Can a neutral be smaller in size than the current carrying conductors? Or does she need to run another #2 to be correct?
Thank you.
Thank you.
