Grounds and Neutrals must be separated?
Darren Emery
Manhattan, Ks
What section of the IRC requires the grounds and neutrals to be separated, other than at the main bonding jumper in the service equipment? I have found the pertinent section in the NEC, but not in the IRC.
if you can't find it in the text ( and i can't either, i hinge on E3301.1, last sentence in the paragraph. i use the NEC. any electriciain that doesn't know that at subpanels ( after first point of disconnect) grounds and nuetrals get seperated,and apply by that rule probably needs a quick lesson in parallel paths to ground
i found these shortly after I posted....
E3908.6 Load-side grounded conductor neutral. A
grounded conductor shall not be connected to normally
noncurrent-carrying metal parts of equipment, to equipment
grounding conductor(s), or be reconnected to ground on the
load side of the service disconnecting means.
E3908.7 Load-side equipment.Agrounded circuit conductor
shall not be used for grounding noncurrent-carrying metal
parts of equipment on the load side of the service disconnecting
means.
The IRC has a cross reference
APPENDIX Q
ICC INTERNATIONAL RESIDENTIAL CODE ELECTRICAL PROVISIONS/NATIONAL ELECTRICAL CODE CROSS-REFERENCE
