Grouping disconnects revisited
Please, one more time with new information available.
A townhouse is clearly specified as being a "separate building" whereas each side/up-down of a 2-family is considered a "dwelling unit" and is not specified as a separate building like a townhouse is. Townhouse=Separate building and 2 hour separation(NS) and a 2-Family is not considered separate buildings and is only required a 1 hour separation(NS).
Thinking about electrical, do we have to look at 2 family units as 1 building/structure for purposes of grouping disconnects?
If the 2 family units [ meaning "each" 2 family unit - the upstairs &
the downstairs ], are an "all encompassing" structure unto themselves,
and have the proper fire rated separation at any point of connection
to other parts of a structure, I would say "yes", they would be
considered a single structure.
From Article 100 [ `08 NEC ]: Building - a structure that stands
alone or that is cut off from adjoining structures by fire walls,
with all openings therein protected by approved fire doors.
I stand corrected kind sir, with regard to the use of the definition
of a "separate" building & fire walls.....I would still consider the
structure to be a single building though!
FWIW, the `08 NEC HAndbook has some excellent drawings of
the various disconnect groupings on structures.
