"H". and Smoke vents
cda
Basement
A local area code admendment group is proposing requiring automatic smoke vents in "H" over 10000 sq ft. With links 100 degrees above the sprinkler head
Any thoughts good bad????
Peach is it a good design though??
Say automatic vents over a sprinklered flammable storage room????
Not sure that many fusible link options exist that are listed for smoke and heat vents to meet all temperature ranges of sprinkler heads by a 100 degree increment.
165 and 212 tend to stick out in my mind, not sure what they offer today.
http://www.bitorq.com/pdfs/fusible_links/link_temperatures.pdf
Also, what would happen in a few years if FM or UL testing indicated that vents had a negitive impact on the sprinkelr system operation such as ESFR sprinkler systems...... Better to leave the S & H automatic vents as a designer's option. (LIABILITY)
If FD ops want the vents installed, require manually operated S&H vents, and remove the automatic operation of these vents.
That is what I an thinking
Depending on where the head is located, seems the vent may open before or close to the head going off
And also say you have a flammable storage room on fire and the vents open, may have a nice candle coming out of the top
Seems like depending on location of sprinkler head in relation to the vent
If the head is going off around 200, and the vent is higher up then the head, seems like the vent is going to go not much after that.
When ceiling temps are reaching 1000
Below is from FM Global Property Loss Prevention Data Sheets 2-0 January 2011. Why not go with an organization that has done full scale testing on this instead of guessing???
2.1.1.7.1 Heat and/or Smoke Vents
Do not install automatic smoke and heat vents in facilities equipped with sprinkler protection; manual heat
and smoke vents, however, are acceptable. If local codes require the installation of automatic smoke and heat
vents, do one of the following:
(a) Install vents that are FM Approved for occupancies protected by quick-response Storage sprinklers.
(b) Install FM Approved vents equipped with a standard-response 360°F (182°C) nominal thermal
activating device.
© Install quick-response sprinklers directly under the vent opening on a maximum 4 ft (1.2 m) linear and
16 ft2 (1.5 m2) area spacing. Position the centerline of the sprinkler’s thermal element in accordance with
the guidelines outlined in Section 2.1.3.2.4. Ensure these sprinklers have, at a minimum, the same
K-factor and orientation as the adjacent ceiling-level sprinklers and are fed by sprinkler piping no smaller
than the ceiling level branchlines. Sprinklers located under the ceiling vent and installed as outlined above
do not need to be added to the hydraulic design of the ceiling sprinkler system. See Figure 1a for a
diagram of this arrangement.
ok some reason it was added in the 2003 IFC 910.2.2 and taken out of the 2009 IFC, make that it was taken out of the 2006 IFC
anyone have the reason it was taken out of the 2006??????????????
We had an account that had mechanical vents held in the shut position by fusible links. The smoke detector, by a relay, sent voltage to a fusible link. The voltage melted the solder, the links fell out and the 6 foot x 6 foot vents popped open. The first time we tested the FA, no one told us about the links. We had to gather all the solder we could find and have the links soldered together. Then it took 4 guys to hold the vents closed while the links were installed. We never tested that smoke detector again. But, in case of fire, the stage would have been vented quickly.
http://www.globetechnologies.com/
ok some reason it was added in the 2003 IFC 910.2.2 and it was taken out of the 2006 IFC
