Any thoughts on the permissibility of the 30x48 hand dryer clear floor space overlapping the maneuvering clearance of an ADA stall door of a multi-fixture restroom? The hand dryer is recessed so not a protruding object and the device itself does not impede the door maneuvering clearance. However the clear floor space for the dryer and door overlap.
I suspect this comes down to an interpretation of ANSI 603.2.3 and whether or not a hand dryer is a "fixture".
603.2.3 Door Swing
Doors shall not swing into the clear floor space or clearance required for any fixture. Doors shall be permitted to swing into the required turning space.
I understand that this is not the most desirable layout but it's looking like the best option assuming it meets code and ADA.
603.2.3 Door Swing
