1st edition.Which code edition?
Wow, you must have an old book. I’m using the 2015 edition.1st edition.
THANK YOU RON.Per the detail, the dimension of "X" (as I marked up below) must be 1-1/4 inches. The distance between the bottom of the handrail to the bracket extension to the wall must be 1-1/2 inches. However, this can be reduced by 1/8 inch for each 1/2 inch the perimeter of the handrail exceeds 4 inches. Since your handrail has a perimeter of 5 inches, the 1-1/2-inch requirement can be reduced by 1/4 inch (1/8 inch for each 1/2 inch over 4 inches). Thus, the required dimension should be 1-1/4 inches. The design as shown does not comply since the dimension of "X" would be 1 inch based on the dimensions given.
Thanks. Squared away...Does the elbow of the support bracket ... the point where it transitions from horizontal to vertical ... need to fall inside the edge of the rail? The way its drawn, there will not be 1-1/4” at the point of the bracket.
Well, when your state is still a tad archaic...Wow, you must have an old book. I’m using the 2015 edition.
Thank you. We made changes to compensate for this.
THANK YOU RON.
Do you have concern about the 1/2" handrail thickness?Per the detail, the dimension of "X" (as I marked up below) must be 1-1/4 inches. The distance between the bottom of the handrail to the bracket extension to the wall must be 1-1/2 inches. However, this can be reduced by 1/8 inch for each 1/2 inch the perimeter of the handrail exceeds 4 inches. Since your handrail has a perimeter of 5 inches, the 1-1/2-inch requirement can be reduced by 1/4 inch (1/8 inch for each 1/2 inch over 4 inches). Thus, the required dimension should be 1-1/4 inches. The design as shown does not comply since the dimension of "X" would be 1 inch based on the dimensions given.
Interesting question. ADA does not have a minimum dimension, IBC says for non-circular format the max is 2-1/4 and min is 1”.Any thoughts on the 1/2-inch rail thickness? Just realized this may be an issue...
Yes I saw that and just wondered...you would think ANSI A117.1 would have hit that.Interesting question. ADA does not have a minimum dimension, IBC says for non-circular format the max is 2-1/4 and min is 1”.
The most commonly adopted ver.s of A117.1 are the same wording in 505.7 as 2010 ADA.Yes I saw that and just wondered...you would think ANSI A117.1 would have hit that.
So you are thinking the 1/2-inch complies even though it appears contradictory to 1012.3?The most commonly adopted ver.s of A117.1 are the same wording in 505.7 as 2010 ADA.
The 2.25" is widest point, thus the flat bar with a 2" width and 1/2" height is actually closer to 2-1/16" for the measurement.
The 2 examples below show the measuring and I pasted the 2010 ADA Sec 505.7.
Flat bar handrails are used all the time on projects and comply with ADA, ANSI A117.1 and IBC..., the only time they get flagged is when the fabricator does not slightly chamfer the edge, that is rarely done, or should I say should never be done, the chamfer is mostly done for the applied finish adherence, though Designers try to push harder edges.
The 4" minimum, perimeter does limit to larger sizes, one we see many times they try to sneak in is 1-1/2" wide by 1/2" high, this is a size that if you don't like the feel an inspector can call non-compliance if the material is measured with calipers. Most materials are polished and cleaned removing material and normally reducing the 1.5x0.5 to be under the 4" Min.
2010 ADA for ref.
What is your thought on the 1/2-inch thickness dim??Just a side note, the edges of the handrail must be rounded to a radius of 0.01 inch.
E/H,Tbz ... where do yo7 see that 1/2” is acceptable?
