alora
Silver Member
Change-of-use project (R-to-M). Existing building constructed in the 50's, with 18" raised FFE, and (3) 6" risers from grade to front entry patio. There is a lengthy historic overlay zone review process if any exterior work is done to the building. Currently, there are no handrails on either side of the steps from grade to the patio.
1009.10 Handrails. Stairways shall have handrails on each side and shall comply with Section 1012. Where glass is used to provide the handrail, the handrail shall also comply with Section 2407.
3. Decks, patios and walkways that have a single change in elevation where the landing depth on each side of the change of elevation is greater than what is required for a landing do not require handrails.
DEFINITIONS:
STAIR. A change in elevation, consisting of one or more risers.
STAIRWAY. One or more flights of stairs, either exterior or interior, with the necessary landings and platforms connecting them, to form a continuous and uninterrupted passage from one level to another.
How would the above example be viewed? Does "a single change in elevation" from the exception mean one riser only? With that in mind, when does a stair actually become a stairway?
Thanks!!
DEFINITIONS:
Thanks!!
