HVAC contractor pulls permit to install a replacement A/C unit. Upon inspection you read the A/C name plate and determine the breaker size requirement and proceed into the building to fine the panel. You find the breaker and its not label correctly. You write up a correction report and send it to the HVAC contractor. The contractor claims his crew only worked from the disconnect outside and never went inside to verify the breaker size, not his problem, call an electrician or owner? So now I've got a 30-amp breaker labeled: smokes/util outlets".
This is kinda like the CSST bonding, the plumber sez that's the electricians job!
