I am pretty sure his boss and the architectural drawings both called out the ceiling height. I'm extremely confident about that.Looks like he expected the ceiling to be lower since the primer stops below the ceiling.
703.5 Marking and identification. Where there is an accessible concealed floor, floor-ceiling or attic space, fire walls, fire barriers, fire partitions, smoke barriers and smoke partitions
or any other wall required to have protected openings or penetrations shall be effectively and permanently identified with signs or stenciling in the concealed space. Such identification shall:
1. Be located within 15 feet (4572 mm) of the end of each wall and at intervals not exceeding 30 feet (9144 mm) measured horizontally along the wall or partition.
2. Include lettering not less than 3 inches (76 mm) in height with a minimum 3/8-inch (9.5 mm) stroke in a contrasting color incorporating the suggested wording, “FIRE AND/OR SMOKE BARRIER—PROTECT ALL OPENINGS,” or other wording.
Agree. Was any of ceiling grid installed when sign was added?Looks like he expected the ceiling to be lower since the primer stops below the ceiling.
Do you know if he or his boss can read English?I am pretty sure his boss and the architectural drawings both called out the ceiling height
yesI don’t think i have seen that style of grid wall angle. Does it automatically create a reveal?
