Early E
I've had zero success in trying to get anywhere with my local tax assessor in that my covering my "unfinished walls" with sheetrock was a necessary task because leaving kraft faced insulation exposed is not allowed. I have 2 rooms upstairs on my plans that are clearly marked on my building permitted plans as "future expansion". I insulated the areas because I have room in truss cape cod style home and covered the walls with sheetrock and taped them. I only taped them or what I call "fire taping" tape imbedded in 1 coat of mud for ahering the tape to and sealing off as we typically do in commercial above ceiling wall and ceiling assemblies requiring a level of fire rating. I got my certificate of occupancy and my inspector even noted that the rooms above are for storage. I need something out of the code books to show that covering the kraft faced insulation is mandatory if anyone has a link I can pull up and print that shows this. This basically will show I was correct at grieveance for taxes when I take this up with SCARs/next level of getting my GLA/gross living area adjusted to reflect a reduced square footage for the sake of taxing me according to what I have, not what he thinks it can be later like an unfinished basement is to one that is finished.
Thanks in advance.
Thanks in advance.
