hi lo door viewers???
syarn
Silver Member
Philadelphia, Pennsylvania, United States
3 story; IIB; NFPA13R; 68000sf apartment building (R2); NJ IBC 2006; ANSI A-117.1-2003;
does a specific section of the accessibility code require "hi" and "low" door viewers similar to the requirement for hi-lo drinking fountains?
Ansi 1002.9
From the new ADAAG
809.5.5.2 Identification. A means for visually identifying a visitor without opening the residential
dwelling unit entry door shall be provided and shall allow for a minimum 180 degree range of
view.
Advisory 809.5.5.2 Identification. In doors, peepholes that include prisms clarify the
image and should offer a wide-angle view of the hallway or exterior for both standing
persons and wheelchair users. Such peepholes can be placed at a standard height and
permit a view from several feet from the door.
ADA does not apply to most apartment buildings
ICC/ANSI A117.1-2003
1005.5.2 Iden ti fi ca tion. A means for visu ally iden ti fy ing a vis i tor with out open ing the unit entry door shall be pro vided. Peep holes, where used, shall pro vide a min i mum 180–degree range of view.
