jpranch
Platinum Member
Need some help / expert advice on this one. The following is proposed by a building owner:
"The products that will be stored inside this building are motor oils, Transmission fluids, and hydraulic oils which have flash point ranging from 350 degrees to 500 degrees which will be stored in those tanks and also will be stored in 55 gallon and 5 gallon containers on the shelves. The maximum quantity we would be storing is some where around 200,000 gallons (1.5 million pounds)"
Sure smells like a high hazard use? What say you?
