Hinged Shower Door Swing
Francis,
Not specifically stated in the IPC, however, ...in an Accessible \ ADA compliant install, the controls
and operating mechanisms are required to be Accessible, which would require a minimum clear
floor space at the controls, handles, etc.......A lot of Commercial shower applications do not have
a shower door installed at all.......Some use a shower curtain, and others have just the opening
to the shower compartment without any door or curtain.
See this link from the `12 IBC:
http://publicecodes.cyberregs.com/icod/ibc/2012/icod_ibc_2012_11_par156.htm
Also, see Section 608.7 in the `09 ICC A117.1, ..."can't block the controls and operating
mechanisms in a shower compartment."
If a door swings inward, it would have to be a very big compartment to not block the
operating controls & mechanisms.
Is it a "Roll in" type, or a "Walk in" type ?........I'm still curious about the
clearances in the compartment, ...others may be too !
Thanks!
I thought that the door had to be outward swing due to safety purposes. how would you get someone out in case of an emergency, yes I know break the glass.
Well to arouse more curiousity; accessibility will not be required.
Here's an apartment constructed in 1926; the one on the far side is an apartment/office constructed in 1880 was added onto a 1825 structure that wraps around that high rise with walls full of windows on the lot line. However the shower is in one of many built between 1900 - 1967; all these and many more have not sprinklers, partial fire alarms installed voluntarily (not a retrofit requirement), little if any insulation and are exempt from accessibility.
Love the the way they preserve these landmarks!
It's rehab time here too! 1920 brick w/ lathe and plaster construction, no sprinklers, two unenclosed stairs, one narrow enclosed stair, apartments are on floors 2, 3, & 4 - no accessibility required. Inside width of building is less than 18'-6". The fire escape discharges onto an adjacent building. Windows on lot lines.
There is no way I would live in this place, even after it gets upgraded to safer conditions.
