EliasFernandez
Good afternoon Everybody,
I have a customer who I am doing a pool barrier inspection for here in Texas. Section 305.2.5 of the 2018 ISPSC (pool code) says that " Where the barrier is composed of horizontal and vertical members and the distance between the tops of the horizontal members is less than 45", the horizontal members shall be located on the side of the pool."
My questions are:
1) if both neighbors have a pool is this requirement null?
2) if either one or both neighbors do not have a pool and the members are less than the required 45" apart and the fence is already finished ( because the customer didn't call before starting the project as they typically do) what would/could the legal repercussions be that you all are aware of?
I currently require my customers to install a stud cut at a 45-degree angle directly above the mid rail less than the required 45" by the code on the non-pool side so that somebody cannot get a 'toe hold' on the horizontal member less than the allowed 45" and get into the poolside.
Any advice is appreciated
My questions are:
