How to Calculate Non-Separated Use w/H Occupancy
Markmax33
Bronze Member
San Diego CA
I was reading the building code today and trying to calculate the non-separated option for a building with multiple occupancies. The exception says, "H-2, H-3...shall be separated from all other occupancies in accordance with 508.4."
Which of the following are true:
1. This means that the non-separated use is calculated with the H-Occupancy floor area BUT the H-occupancy portions are separated.
2. This means that floors with H-occupancies cannot use non-separated use at all and must be calculated as separated. (This is what the code commentary book says!)
3. This means that the H-occupancies must be separated, but you the non-separated ratio is calculated upon the next most restrictive floor area and the ratio for the h-occupancy uses the h floor area.
A-2 occupancy B occupancy F-2 occupancy H-2 occupancy M occupancy
Aa = 13,395 ft2 Aa = 32,430 ft2 Aa = 32,430 ft2 Aa = 9,870 ft2 Aa = 17,625 ft2
Floor areas:
Floor A-2 Floor Area A-2 Ratio B Floor Area B Ratio F-2 Floor Area F-2 Ratio H-2 Floor Area H-2 Ratio M Floor Area M Ratio
3 31,321 ft2 2.338 3,210 ft2 0.24 3,210 ft2 0.24 8,000 ft2 0.597 1,532 ft2 0.114
2 1,351 ft2 0.101 35,135 ft2 2.623 3,513 ft2 0.262 6,555 ft2 0.489 35,135 ft2 2.623
1 3,456 ft2 0.258 80,000 ft2 5.972 531 ft2 0.04 533 ft2 0.04 1,531 ft2 0.114
Thanks! - Mark
A-2, B, F-2 and M can be one fire area (no-separated), each a fire area (separated) or a mixed of the two. The Group H-2 has to be separated (in its individual fire area)
Occupancy Group Allowable Area(from your post)
A-2 occupancy 13,395 sq ft
B occupancy 32,430 sq ft
F-2 occupancy 32,430 sq ft
M occupancy 17,625 sq ft
H-2 occupancy 9,870 sq ft (7,000 + 2,870)
H-2 can not exceed allowable area=9,870 sq feet
If you use non-separated (all occupancies except H-2) the most restrictive is Group A-2 so allowable area =13,395 sq ft
Actual area of mixed occupancy/13,395 + Actual Area of H-2 /9,870 ≤ 1
I didn't understand any of what you two just posted... and I teach the stuff!
Markmax33, what was that mishmash of numbers and letters at the end of your post?
In order to go non-separated you simply apply most restrictive area for all the various uses.
If you max out the non-separated area allowance you will need to create a separate fire area for the H use.
Sum of the ratios for separated uses won't work as your non-separated side is already at a value of 1.
The issue is the code does not permit all occupancies to exist together in nonseparated harmony. It specifically prohibits Group H from being a nonseparated occupancy (NSO).
The OP is seeking to have a mixed use building with Group H, but meeting the separated occupancy (SO) provision for the Group H area while the remaining mixed uses apply the nonseparated use provision.
The trick is, it's a little unclear how to mix and match SO and NSO, though there is a complimentary logical approach.
From the Commentary:
When one or more of the occupancies is a Group H-2, H-3, H-4 or H-5 high-hazard occupancy, the nonseparated occupancies option could not be applied for the Group H portions of the building (Exception 1). Any Group H occupancies would need to be separated as required by Section 508.4 for separated occupancies.
I read that the NSO can be applied to the remainder of the building, outside the Group H portions of the building. Therefore, the commentary does appear to support such an approach.We've sought to apply a similar weighted mix and match approach to address the MAQ of hazardous material storage in and out of cabinets within a common control area.
