How to determine wall bracing for tall walls
mont1230
Champaign, Illinois
An example: See attachment. If a Great Room is open above and has no interior walls connected to it and the walls are above 12' tall, how do you determine wall bracing? The code allows 2x6 studs at a height of 24', but can't find anything in the code to determine wall bracing at a height above 12'. At this point, is a licensed designed professional required?
MX-5110N_20141203_085108.pdf
mont1230,
I agree with the other esteemed Forum contributors.
From the `12 IRC, Table R602.3.1, Note " a ": Design required."
You did not mention anything else, but as long as you're planning
to get a design for the height, ...are you planning to have a design
for the wind bracing as well ?
