Rudag
I am having difficulty understanding this table. I am reviewing a 5,000 square foot type III B mixed use building. Half of the building is and occupancy class B, office, and the other half is a class F-1.
While using table 508.4 to determine the fire separation between the Office use the F-1 occupancy no fire separation is required.
This is where I get confused, the fire separation between an Office and a F-2 occupancy requires a 1-hour separation for a sprinkled building and a 2-hour separation for a non-sprinkled building.
A F-1 occupancy is a Low to Moderate-hazard occupancy. A F-2 occupancy is a Low-hazard occupancy. F-1 should be more restrictive than F-2. Logic tells me that fire protection between an Office and F-1 should be greater than the fire protection between an Office and F-2.
I do not understand why a use that is a has a greater likelihood of causing a fire or feeding a fire because of its flammable contents does not require a fire separation, yet the use that has a lower likelihood of causing a fire does. Shouldn't a Low to Moderate-hazard use offer more fire protection than a Low-hazard use?
I must be missing something simple, please point me in the right direction.
Thanks.
Thanks.
