Hyrax4978
Trying to figure out the use of a small yard tool store. I clearly have some storage and Business use. My question is; the area of the building where they have aisles kind of like a small retail store, is that mercantile, or B use? Its not under 10% so not accessory. I see auto show rooms are B uses. But this is more like partly a small yard tools such as chain saws, weed whackers on the perimeter walls and partly belts, filters, toys, tee shirts, etc. on the aisle shelving. There is also a parts counter where you go to order parts or buy parts. Are the aisle shelving areas Mercantile or B use. Would the chain saw and weed whackers be M or B. Drug stores and sales rooms are mercantile. Most of the people are just walking in, going up to the counter and leaving. Its not a store that most people would walk the aisles like you would think in a truly mercantile area. But some will shop the small tools but that seems kind of like a B use and not M.
Also client is trying to save a few bucks. of course they always turn to the sprinklers for the savings. Trying to confirm if he can even omit them at this point and still save money. Sometimes omitting sprinklers costs the clients more in rated walls etc.
Looking at S-1, M and B at this point. if the M is really M based on my question above. building is approximately 15,000 sf. assume S-1 of just over 6,000 SF and M of just over 6,000 sf. and about 3k of B use.
I was looking at using a nonseparated type thought, but then starting thinking about section 903. even though my uses are around 6k, if I don't have rated walls, then my fire areas are the entire floor area correct? so even though my S-1 and M uses are only 6k each, because I'm not rating any walls my fire areas become the entire 15,000 SF triggering sprinklers. correct? To avoid sprinklers I need a 3 hr. wall compliant with 707.3.10
