All in one building?lee1079 said:Does anyone know single family or townhouse can be designed per IBC in lieu of IRC? I have a project that includes both commercial buildings and single family/townhouses. I wonder if I could just design all per IBC.
They are on the same site but not in one building.cda said:All in one building?Or townhouses mixed with commercial in the same building
Love to so I deal w/ one less code but below is what IBC says. See the exception.fatboy said:Design it as an R-2............
More than likely with this scenario, the ahj will not allow Ibc to used for entire projectlee1079 said:They are on the same site but not in one building.
Whale, the problem in the great State of Texas is that the ""pol I tic anns"" outlawed fire sprinklers in homes a few legislative sessions ago. Unless a city had a pre existing fire sprinkler ordinance in place.JBI said:If Texas has adopted a newer version of the IRC that includes mandatory sprinklers then there is little difference between the IRC and IBC for Townhouses.
There is a definition of "fire wall" in the IBC, but not in the IRC. It could be argued that if you are using a "fire wall" to separate occupancies, you are building something that is not in the IRC. This kind of construction is traditionally attempted under the IBC.So the situation is similar to the original above, except for it is in one building. Except per the definition of fire walls, these are technically separate buildings, with property lines between them too.
I did that for an entire career....I was known to practice medicine without a license. Had anyone inquired I would have been comfortable performing marriages. There was a time when I was a licensed hot air balloon instructor and I've never been near one.. Vegas Paul was a licensed nuclear reactor operator ...and he was in one.you are likely practicing architecture or engineering without a license.
