A new commercial building is being fitted with high-efficiency fuel-burning appliances that produce condensate. The design includes a condensate drainage system that utilizes CPVC piping. The piping is planned to have a uniform diameter of 3/4 inch from the drain pan connection to the point of disposal. The system is also designed to include a condensate pump located in the attic space.
Based on IMC Section 307:
- Is the chosen material (CPVC) for the condensate drainage system compliant with the requirements of [M]307.3 Drain pipe materials and sizes of the IMC?
- Does the piping diameter comply with the minimum size requirements as per [M]307.3?
- Considering the location of the condensate pump in the attic, what specific requirement must be adhered to as per 307.6 Condensate pumps to ensure proper safety and functionality?
