When I lived in Daytona Beach I saw an olympic sized pool raised 3'. It happens here too.gfretwell said:It is actually pretty rare that anyone drains a pool here. They tend to pop out of the ground.Most water coming out of a pool is overflow from rain water.
Yes, but I still get in the hole with electricians I never met before.gfretwell said:In my county the pool steel guys generally do the rebar, niche, ladder cup bonding and stub out a #8 or two for the screen cage, deck and any other bonding necessary. The structural inspector and electrical inspector will sign off before they shoot the shell. After that they need an EC to do the rest of the wiring and the electrical inspector does the rest of the inspections. The plan review wants to see the anti-entrapment methods, detail on steel, bonding plan and sometimes a hydraulic calculation (turnover speed).
Usually the inspector is happy about the potting on the niche if you leave the kit wrapper on the deck. YMMV and it is better to ask than to guess wrong. They may want a rough inspection before they plaster and fill the pool.
I never understood that one. A properly balanced pool will test about the same as chlorinated city water.mtlogcabin said:The drain and filtering system. Public Works will not let them drain directly to the sanitary sewers as the chlorine messes up the bacterial levels in the sewer plant.
I'm not sure about how things are done everywhere, but in this area,the sanitary sewer billing rates are based on the amount of water"I never understood that one."
