Yikes
Gold Member
I have a 3 story Type V-A apartment building and at the second floor level there are some paralam beams resting on 6x6 wood posts buried inside a 1 hour wall.
The inspector says the wood post is a "column" and therefore must be individually encased with 1-hour protection per 704.2, as if it were a steel frame. I've had at least a dozen buildings plan-checked and built in this jurisdiction before, and this has never been an issue.
I'm thinking it's more like "integral elements in load bearing walls of light-frame construction" per 704.4.1 and therefore doesn't need additional layers of Type X inside the membrane protected wall.
Questions:
1. When discussing a structural frame, is there any substntive difference between naming something a "post" vs. column? (I tend to thinkof a post as integral to the wall, whereas a column is a freestanding element, but this cpuld be an irrelevant distinction).
2. When 704.4.1 mentions "boundary elements", what does that mean? Exterior walls? Or any wall (exterior or interior) that defines the "boundary" of a room? Or is it the "boundary" of a shear panel?
Questions:
