Indoor Compressed Natural Gas Facility
retire09
Silver Member
Alaska
What would the occupancy classification be for an enclosed facility approximately 7,000 sf housing 2 large compressors used to compress natural gas and pump it into an underground storage facility several hundred feet away? If this would be an H classification, what would actually trigger that classification?
is the compressor the only thing in there??? as in more for weather protection then anything???
Nothing is in the building other than the compressors.
They are only in a building due to the location in Alaska. -20 degrees and lots of snow.
Ah weather protection
Not electrical, but seems like at least the electrical would have to be for hazardous area
Is your question if you call it an H, then do you sprinkle it???
I don't see the need to call this an H occupancy or to sprinkler the building or provide the ventilation required for an H.
I may be wrong, but I don't see the concern for natural gas in a closed welded pipe system inside a building that is only occupied for maintenance of the equipment.
This is basically an equipment enclosure for the protection of the equipment and not intended for occupancy.
Do I have a valid point?? Is there some code language that will support this being a less restrictive occupancy?
