Inside the electrical panel, connections
Using the IRC, what violations do you see? Use section numbers for learning please.
Don't have book with me, but here goes
dissimilar metals connected under one terminal
double conductors under one terminal/screw, need to check listing
grounding conductor and grounded conductor under same screw terminal
grounded conductor nicked near terminal block
sheathing on ungrounded conductor not removed enough (just guessing at this point)
bond screw not green?
