steveray
Yep...Seal them up and let hem rot because no one knows how to waterproof the outside....
Yea, I get it. Its a tough one to grab a hold of. The difference is with the two words, Controlled Vs Uncontrolled. The Energy code (and Building Science) is suggesting that infiltration witch is uncontrolled is bad.You now make the house so tight, you now need to put some holes in it with fans to changeover the air every day.
Seems like a waste and "energy" to me.![]()
It may be a waste of energy in moderate climate zones, but anywhere with a significant number of cooling or heating days, mechanical ventilation makes way more sense. Having 7-8 air changes per hour in a house means you are paying to heat or cool the outside air to whatever the design conditions are that many times per hour (assuming pressure differential with outdoor). With proper air sealing, you get that number down to 0.3. The mechanical system is either an ERV or HRV, meaning that energy lost by ventilation without mechanical systems can be recaptured. Typically, mechanical ventilation is 20-30 times cheaper than the alternative.I have gone around and around with regards to stapling the insulation, I dont care as long as its not compressed , cut outs are proper at electrical boxes and plumbing etc....
The energy code is also a little ridiculous. (in my opinion)
I like my leaky old house, i get fresh air w/o opening a window. HAHA
This is not true. Many manufacturers specify either. Example: https://www.certainteed.com/resources/IGInstallationBasics200608.pdfManufacturers installation instructions have ALWAYS required the flange to be stapled to the face of the stud. I have pi.....ed off a lot of contractors over the years pointing this out. My specs have always said thi but know one seems to read anymore.
Can you share your single page document? Thanks!The energy code stuff is interesting and overall contains a lot of nonsense. I find ResCheck to be a big, hot, pile of steaming "stuff". We adopted the 2018 IECC and then basically amended out every bit of it. We now have a bit more than a single page document that exceeds ResCheck. Contractors love it and so do I because every single dwelling meets a well defined minimum standard.
