ETThompson
Hi
I have a small apartment project I'm working on. The units are served by an exterior breezeway, but we have enclosed stairs, disconnected from the main apartment block (originally they were open air, but because they are hard up against the property line we had to enclose).
MEP engineer plans to use baseboard heat but says cooling not required. 3 stories, VB Construction, new construction. About 10k sf for the project.
We are under the 2017 Ohio Building Code, which is based on the 2015 IBC. The Ohio Building Code adopts ASHRAE 90.1-2010 or IECC 2012.
Because of the enclosure chart in ASHRAE, which calls for R-7 or so for "semi-heated" spaces with mass walls, I'd always thought I had to insulate spaces like these. One of my colleagues tells me though she never has on her projects. I don't have a full copy of the ASHRAE standard.
Am I right in thinking that ASHRAE would require insulation for these spaces? Her argument is its not a "habitable space" and therefore does not require it.
Thanks
Thanks
