I hadn't thought of the bolt embedment as a way to provide a specific code section for interior slab/footing thickness.....but I like it. I use this:
R401.2 Requirements. Foundation construction shall be
capable of accommodating all loads according to Section
R301 and of transmitting the resulting loads to the supporting
soil. Fill soils that support footings and foundations shall be
designed, installed and tested in accordance with accepted
engineering practice. Gravel fill used as footings for wood
and precast concrete foundations shall comply with Section
R403.
·:·In order to fulfill its role in the complete load path, the
foundation must support the required design loads and
transmit these to the soil. The phrase "accepted engineering
practice" in this section means common practice
that is acceptable to the code official of the
jurisdiction.
Often, the slab has been poured before I realize there is a load bearing wall above it (I know, but I'm not allowed to require plans!) so when I get there it usually results in a phone call to the mayor and an engineer!
