Mech
2009 IBC
From Table 720.1(3), Minimum protection for Floor and Roof Systems, the floor construction of Item 21-1.1 is "Wood joists, wood I-joists, floor trusses and flat or pitched roof trusses spaced a maximum 24″ o.c. with 1/2″ wood structural panels with exterior glue applied at right angles to top of joist or top chord of trusses with 8d nails. The wood structural panel thickness shall not be less than nominal 1/2″ nor less than required by Chapter 23."
What is a wood joist? My floor is framed with 2x8s. Is a 2x8 considered a wood joist for this assembly?
Thanks.
ps - I am looking for a 1 hour rated floor/ceiling assembly using 2x8 @ 16", gypsum board ceiling, and a 3/4" T&G subfloor that permits fiberglass insulation. I do not know what the floor finish will be. I looked in the IBC, UL, and GA 600; no assemblies using 2x8, only 2x10.
Thanks.
