If a support column is present in the habitable space (living area) of a dwelling and the column was boxed in with drywall 6" on all four sides, is a receptacle required under NEC 210.52(A)(2)(1)?
(2) Wall Space. As used in this section, a wall space shallinclude the following:
(1) Any space 600 mm (2 ft) or more in width (including
space measured around corners) and unbroken along the
floor line by doorways and similar openings, fireplaces,
and fixed cabinets that do not have countertops or similar
work surfaces
work surfaces
