Yikes
California Existing Building Code 505.3 has condition #2 for EERO replacement window sizes in dwellings that are not undergoing a "change in occupancy".
If a residence is getting replacement windows, and it is apparent that the owner is now using a former non-bedroom (such as a living room as a bedroom, does that meet the definition of "change in occupancy"? Here's the code section that I'm having a hard time understanding (see red lettering).
I'm confused by the terms "change in occupancy" vs. "change in occupancy classification" vs. "change in character of use".
Exception: The building need not be made to comply with Chapter 16 of the California Building Code unless required by Section 506.4.
[A] CHANGE OF OCCUPANCY. A change in the use of a building or a portion of a building that results in any of the following:
There is no definition in the code of the word "use" other than usage of material.
505.3 Replacement Window Emergency Escape and Rescue Openings
Where windows are required to provide emergency escape and rescue openings in Group R-2 and R-3 occupancies and one- and two-family dwellings and townhouses regulated by the California Residential Code, replacement windows shall be exempt from the requirements of Sections 1030.2, 1030.3 and 1030.4 of the California Building Code and Sections R310.2.1, R310.2.2 and R310.2.3 of the California Residential Code, provided that the replacement window meets the following conditions:
Section 506 Change of Occupancy
506.1 Compliance
A change of occupancy shall not be made in any building unless that building is made to comply with the requirements of the California Building Code for the use or occupancy. Changes of occupancy in a building or portion thereof shall be such that the existing building is not less complying with the provisions of this code than the existing building or structure was prior to the change. Subject to the approval of the code official, changes of occupancy shall be permitted without complying with all of the requirements of this code for the new occupancy, provided that the new occupancy is less hazardous, based on life and fire risk, than the existing occupancy.Exception: The building need not be made to comply with Chapter 16 of the California Building Code unless required by Section 506.4.
506.1.1 Change in the Character of Use
A change of occupancy with no change of occupancy classification shall not be made to any structure that will subject the structure to any special provisions of the applicable California Codes, without approval of the code official. Compliance shall be only as necessary to meet the specific provisions and is not intended to require the entire building be brought into compliance.***
- A change of occupancy classification.
- A change from one group to another group within an occupancy classification.
- Any change in use within a group for which there is a change in application of the requirements of this code.
- The replacement window is the manufacturer's largest standard size window that will fit within the existing frame or existing rough opening. The replacement window shall be permitted to be of the same operating style as the existing window or a style that provides for an equal or greater window opening area than the existing window.
- The replacement of the window is not part of a change of occupancy.
